- North Ridgeville, OH
Thanks, Terminator.I don't have any good pics of it. But it's where I have the arrow pointing. It's what the throttle blade actuator arm rests against when the springs have it fully closed.
This thread has become just as much about will Gordo show as it is about fixing this tremor. LOL
I'm holding hostage a socket Gordon left behind when he tried to fix my soft brakes.This thread has become just as much about will Gordo show as it is about fixing this tremor. LOL
No, that hasn't been tried because I don't have a spare PCM. And it seems a bit extreme at the moment.So I haven't followed every detail of this thread...but after @Rodeo Joe 's recent experience, have you considered trying another PCM?
My apologies if that has already been discussed.
Tune in next week! Same Bat time same Bat channel!I'm holding hostage a socket Gordon left behind when he tried to fix my soft brakes.
Our live studio audience waits with bated breath to find out the fate of the socket.
Will our hero save the socket...or leave its fate in the hands of an evil & perverted tool deviant and his Car?
Proof of life photo attached.
Is it idling any lower than normal when you drop it in gear? If so, have someone get in the car, drop it in gear while you adjust the throttle plate a smidge to bump up the RPM back to normal and see if that helps... if not, adjust it back and check it off the list.No, that hasn't been tried because I don't have a spare PCM. And it seems a bit extreme at the moment.
The car drives & performs beautifully and is silky smooth...except for that idle tremor in gear.
No codes...and the plugs, wires, ignition coils have all been replaced with new Autolite/Motorcraft parts.
The tremor started 2-3 weeks after these parts were replaced.
Since then, the IAC & MAF have been properly cleaned. EGR was cleaned & tested good. Throttle body also cleaned.
All vacuum/emissions lines have been replaced...even the ones behind the passenger-side bumper/fender.
Other parts have been tested good.
Gordon says he's going to pop over to my place with a spare IAC & MAF to try out.
But so far, the tremor has been a stumper that's gone on months.
Posted about that already...I put the old ignition coils back in a week or so ago. No change.Do you still have the old parts? I'd swap them back, and see what happens. There's little qc these days, so a bad new one isn't unheard of. A leaky coil usually leaks more the hotter it is.
Terminator suggested that earlier in the day and I've been trying to find the set screw to do that.Is it idling any lower than normal when you drop it in gear? If so, have someone get in the car, drop it in gear while you adjust the throttle plate a smidge to bump up the RPM back to normal and see if that helps... if not, adjust it back and check it off the list.
@theterminator93 ...doesn't this conflict with what you advised on Thursday?The PCM will target 560 RPM idle in gear. If the throttle blade is open so much as to keep the car idling at 800 RPM all the time, it would likely have other repercussions that affect driving characteristics (e.g. accelerating with your foot off the gas and brake when normally you'd coast).![]()
Ah...gotcha.Yes, that's it. It's not milled for a tool to turn. This is a temporary "what happens" kind of thing - just to determine if the reason the idle is wonky is related to too much air entering. Just grab it with pliers on one side and close it slightly (I would lightly score it with a screwdriver or something so you can put it back to normal later), or open it slightly and observe any changes.
The PCM is programmed with the mass of air that gets into the engine with the TB and IAC closed. If reality doesn't match this data somehow, it will cause problems. So we're just adjusting the air through the throttle blade as an intermediate troubleshooting step to determine if it's possible that the amount of metered air entering at idle is off spec.
Not sure I'll be able to adjust the screw...damn thing is frozen.Before You mess with the Idle, Clean the Throttle Blade first; There gets to be a crust at the edges that can cause issues. To adjust it correctly, disconnect the iac electrical connector, while keeping it running with our thumb on the blade. Then adjust the screw to BARELY keep it running. Reconnecting the iac should still run normal. Reset the computer after Reconnecting the iac , it should still run normal.
No...it took me hours to install that octopus of new wires and I'm not keen on undoing all that and redoing it with the old wires.Did you try swapping the old wires back on yet? I really want Gordo to get his socket back!
Battery has no problems that I know of and always starts the car without issue.I had a few tremors the other day. You could see the voltmeter dipping when it had happened. I know that my Battery is passed its date, and that my positive post is imperfectly secured. I'm not necessarily saying that's the reason however
Depends...sometimes 7/11, Maverik, Chevron, 76, Arco AM/PM (if I'm in the mood for those delicious shitty foil-wrapped burgers in the glass warmer).Thinking out loud here, but figured I'd ask. Where are you buying your gas?
Seems like you've checked everything there is to check, with all new parts and everything.
Hmmm.... just a random thought but maybe try a can or two of Liquid Moly Valve Clean... They're small cans but pack a hell of a punch in cleaning injectors, valves, rings everything. Just add a can when you fill it up, run out the tank and add another can next full up. Stuff worked AMAZING in my '77 Maverick.... Hopefully it would work the same for you.Depends...sometimes 7/11, Maverik, Chevron, 76, Arco AM/PM (if I'm in the mood for those delicious shitty foil-wrapped burgers in the glass warmer).
Occasionally, I'll buy a bottle or two of injector cleaner to pour into the tank.
Also recently replaced the fuel filter with another Motorcraft one.
No problem...it was a valid thought.It was just a thought, I was thinking maybe you were getting bad gas somewhere.
