What do those relays do?
High beam and low beam for my headlight harness
The kooks headers are 1 5/8 primaries to 2.5” exits??
I know primary size has an affect on low end torque/ top end power.
What are your power goals with this build??
can you run down your combo real quick??
Db heads?
Mach 1 intake?
Is anything ported??
Yes. but I remember sir will cutting one end off his swaybar, with the k dropped; idk how he stuffed the addco in. But you're more competent than he ever was, lol. I've got to do engine refurbishing. so I'll do the headers on a stand.You do realize I’m dropping the K member and installing headers with the engine suspended next? lol
I’m assuming then kmember spacers are there so the intake clears the hood??
I’m definitely stealing that rolling k-member idea!
Looks like a good time to upgrade the sway bar too...the 1⅜" made mine handle like a different car...definitely glad I did it on mine.
@XR7-4.6 makes sense our hoods are super close to even the stock intake. Maybe when I 4v the bird ill add some, then again I did cut out some of the under hood support so I think that should make up for that.
I had the 1 1/4 bar in my bird for the longest and it helped immensely! Not to long after I got the QA1’s with the SCP recommended 450lbs springs and honestly I didn’t like it. Too soft and the heavy ass saleens rode crappy. Well to me atleast. Soon after I put 550lbs and for me that was the hot ticket. It soaked up the bumps better and less body roll, after that I went with the 1 1/4 front bar because I got it from a steal from a member on the FB group (175$ shipped) and godamn another huge improvement up front! Low key I wish I’d of gone with the 1 3/8 but for that price I just couldn’t afford it.
I remember seeing a post on TCCOA of the guy who I believe got the bars made saying he went with the 1 3/8’s front AND rear and how he praised and didn’t have anything negative to say about that.
