Ericv8thunderbird
		You can add green LEDs to the Autometer gauges, it will almost match the factory cluster at night, I don’t have a shot of my Tbird, but here’s a shot of my old F250 with the green LEDs.
		I got them from: https://www.superbrightleds.com/led...lb-3-smd-led-miniature-wedge-base+color-GreenEric,
Do you remember where you got those green LED bulbs? I could use those on mine.
		I have used that style LED for some years on my Honda, and after some time they start to stop working for whatever reason.
Not sure if it just how they're made or what, but they stop making constant contact and begin to flicker after a year or two. It's super annoying.
The last set of LEDs I got I just stopped caring and now over half my cluster is dark.
		too much current kills them. They're probably going for brightness. Adding a resistor inline would help.
		Most bigger leds have current limiters, two transistors and a diode. Can you pull apart one that failed, and see if there's a circuit board?
		True; I was curious about circuitry.
		Mostly loomed up to where it will be in the engine compartment, just got to run it around the engine to determine final wire lengths.
So you might be able to see the plan based on the remaining wires - water is blue, oil is yellow, and obviously red is B+ battery power and black is ground. I also added wires for a third autometer in place of the wideband gauge if I decided to do that down the road. Plan is I’m running it straight off the battery(well actually off the battery cable from the starter solenoid), grounding to the block and signal wires to the sensors, all uninterrupted(though I did add a fuse in the B+ circuit for safety sake) The relay is there to switch B+ to the gauges using a hot in start/run wire from the dash to trigger and those two wires sticking out in the middle of the loom by the fuse will be the new ignition/ground source for my wideband, which is kind of jerry rigged at the moment.
Should be a really solid circuit. If it weren’t for the catastrophic leak potential of mechanical gauges I’d vastly prefer them for dead on accuracy independent of electrical variance but setting up the circuit in this overkill manner is the next best thing (Plus as I said I do enjoy this kind of crap)
		Now I have the challenge of finding a clean cougar trunk carpet in 2025, yay
 www.ocautocarpets.com
		But why?
Clean engine bay is not so clean anymore.
Also why don't you shift that challenge to making it?
Auto Trunk Mats | Car Trunk Mats | Car & Truck Interior Carpet
Update your worn or torn trunk mat with ACC replacement carpets Get great discounts off of retail and fast shipping directly from the manufacturer.www.ocautocarpets.com
