Moving right along to the bigger project...
So SC pedals are hard to come by and since I'm cheap but brilliantly resourceful? I figured I'd try improvising with one of the missing links of the upcoming 5 speed swap - Modding an auto brake pedal into a stick pedal.
Now the easy peazy solution, and the perfectly acceptable one at that, would be to simply trim the ends off and slip on a smaller pedal pad. In fact, that's not far off what Ford did from 89-92, albeit with a different metal pedal pad. But my Cougar is a 94 and Ford substantially changed the pedal layout for the 93-95 SCs(along with the cage, booster and firewall for the Teves IV ABS system) and me being as picky as I am wanted the newer rarer layout with the brake pedal tucked right along side the accelerator, as seen here...
This pic of course is from the MN12performance archive, I used many pictures from it as a reference for my little retrofit, including the Mustang pedal template as well as a general reference for angles and such (I'll also be using those pedal covers when all is said and done).
First thing I did was find the centerline of the stock auto pedal using masking tape paralleling the pedal arm and marking the specific center with a sharpie.
Next I laid the template to correspond with the centerline. I used the pictures of the back of the pedal in the archive to determine the center and angle of the pedal pad template in relation to the pedal arm, the second pic below you can see the pencil marks I drew. I also glued it down
Now the fun part, I had to bend the pedal arm until the top of the template was parallel with the pivot. This proved to be harder than I thought and tried everything to bend this chunk of 3/8" steel from a BFH and heat to brute force, trial and error brought me to this...
A vice a vice and a big ass wrench with me pogoing on the end(too bad I couldn't get a pic of that lol).
*Note if anyone tries to attempt this make sure to position the arm in the vice so the cruise switch bracket portion won't get bent, otherwise the geometry of everything will be thrown off.
Now that the arm is bent to my satisfaction I let the carnage begin.
Since the auto pedal has a wide diamond shaped stamping vs the manual pedal's round one I had to do some grinding for the pad to fit.
And all done
Took about an hour total. Tools used: Vice, another vice, BFW(big ****ing wrench), bench grinder, a coarse file and some black paint since it got pretty dinged up in the process.
And all done
I didn't intend for it to become a full blown buildup when I got it, just a mild refresh but then I wanted carbon fiber blockers instead of paper. Then I planned to just upgrade the 3-4 shift fork to billet but then I noticed the pad mounts of the 1-2 fork were slightly damaged(the nylon pads broke off and it ground into the syncro slider), so may as well get that too. Then those would be silly to get without the billet shift keys and brass pads... Well I buy all that and I don't replace all the bearings, races and snaprings? Well all of a sudden that's a full blown rebuild I neither want to do, have the time to do or willing to spend the money to do(if it were a T56, then yes).
