The Site That Should Not Be Named
			If you want to clean and protect an engine, run Amsoil OE synthetic
TSTSNBN is “The Site That Shall Not Be Named” AKA our former Ad packed, Canadian owned and operated forum.Coming up is my first post and stupid question. This question is because, while I've been here long enough, I apparently haven't been part of the MN12 / FN10 community long enough to know.
What does "TSTSNBN" stand for?
I know it's obviously something to do with Thunderbirds and Cougars of the MN12 generation, but I don't know what it actually means.
I got some yesterday but haven't changed it yet. I saw the video where the guy cut open the filter after a couple hundred miles and it was sludged up bad, which indicates the oil is doing it's job as intended.Well, my question relates specifically to the new Valvoline product, Restore & Protect. They claim it uses an entirely new chemistry for removing sediments. Allegedly a proprietary molecule (?).
I'm just curious how it affects the filter.
I'll keep an eye on the dipstick to see how it's going, and do an early filter swap regardless.Yes, I saw that, too. Makes you wonder if you should shorten your oil change interval.
Your rearview mirror is supposed to be positioned so you can see what is behind you not look at yourself.I keep an eye on the dipstick while I drive.
TouchéYour rearview mirror is supposed to be positioned so you can see what is behind you not look at yourself.
I wonder if the Frams you ran "back in the day" where quality built as compared to the way they are built now.I used to run Frams on my old '92 V6 Thunderbird. It had 260k miles when the rear shock mounts rusted out. Engine ran great and didn't burn a drop of oil. Their Tough Guard (TG) and Extra Guard (XG) are pretty decent filters. Nowadays I mostly run Wix or Napa Gold.
WHAT??? Oh crap... guess I had better stop dropping the car off at my corner gas station....if you are running recycled oil you got from the corner gas station,
I went to the yard and pulled as many as I could find to replace the ones in my cars. They are holding well.....This could be stupid, or super helpful. Anyone find a good alternative to the plastic nuts that hold the trunk carpet in place at the far rear of the car? Mine are stripped and I'm afraid those I'd get from TBSC shop would be too. Thinking a newer car might have something that would work. Wouldn't even mind cargo net holders of they worked
Yep, those are the ones.I went to the yard and pulled as many as I could find to replace the ones in my cars. They are holding well.....
....as long as I don't touch them.
Are you referring to the screw-in ones that screw onto a threaded shaft to hold the trunk material in place?
I looked through my junk and found the ones with hooks for the mesh bag that goes against the rear of the trunkYep, those are the ones.
You'd have to ask Bill at SCP, as the contact point at the K may not be the same.It looks like I'm going to be grabbing an AJE K member set. No idea if this makes sense, but is there any issue combining that with SCP's front subframe lower engine cradle brace?
