Hmmm, this is something I  should know, but I've never dropped a headliner on these. I can tell you that the lighting wiring is a single wire; ground is provided through the screw into the roof.
			Moonroof and non moonroof visors are different and will have different mounting points. I’m fairly certain the lighting wires are a miraculously prewired part, though you might have to partially drop the headliner to find them anyway
What's the stock size of the 16" sport wheels?
I thought you were upgrading to the J55 brakes though??
I assume these are destined for the beige home wrecker![]()
What do you mean that's what I said the whole timeI am assuming you mean the power antenna?
Looks like light graphite.
The others available were ivory, ebony (black) and light prairie tan.
I honestly don't think it is worth the hassle. I've been fighting with replacement masts since we got ours. I think I'm on #3 right now. I just gave up since my wife mostly drives the car and when she does she doesn't listen to the radio much. As 1997ThunderbirdLXV6 alluded to there is a control box that actually runs the motor in addition to the motor/lift mechanism in the wheel well. I've actually considered converting to the fixed mast style.What do you mean that's what I said the whole time
And if I was to want to wire up a power antenna to my car with a switch how could that be done?
I love the look of a power antenna, but I usually stream music from my phone, my antenna is disconnected. As in always down.I honestly don't think it is worth the hassle. I've been fighting with replacement masts since we got ours. I think I'm on #3 right now. I just gave up since my wife mostly drives the car and when she does she doesn't listen to the radio much. As 1997ThunderbirdLXV6 alluded to there is a control box that actually runs the motor in addition to the motor/lift mechanism in the wheel well. I've actually considered converting to the fixed mast style.
I have a Bluetooth radio in mine so it's not all practicality, I hate the look of the antenna but if I wanted to use the radio I would like to, so I'm planning on doing a power antenna, but I want a switch.The fixed ones typically work better.
New question: is it normal for this connector to get wet during heavy rain or washing the car? Seems like a poor design choice.
Note the gap in the foam insulation. Could some of you check if you have the same gap?
Thank you, Matt.
And yours is the round one. Interesting that they bothered to change the firewall at some point (I'm guessing '96).
Yes, and it seems at least one name for it is "Door lock pawl/lever/clip/retainer". Found it from eBay now: https://www.ebay.com/itm/385388458873That looks like the piece that pivots from the lock cylinder and moves a lever to actually unlock the door. If I remember correctly the lever goes in the clips. The other side does look broken.
