Very old pic. Before I figured out the upper mount mod to make them truly flush
2007ish
Last time I had them
Now hold on just a second. Are you telling me you can replace the headlight bulbs on these things without removing the front bumper cover, left front fender and both doors? I've been working on too many late model cars lately.Speaking of bulbs, there’s so much space between the header panel and core support now it’s almost as if MN12s were designed to use 9005/9006 bulbs in the first place![]()
Yes that is aluminum corrosion. You would have to pick all that out of there and chances are they are pitted pretty badly.
It was probably from sitting in the bag and absorbing moisture. Should always flush out brake parts you're going to store.
I did flush it out but I think by the nature of being a valve it probably retained some old fluid inside and it pulled in moisture. I did the same flush to the lines and they’re still mint.
The good news is I soaked them in penetrating oil for a few hours tonight and scrubbed the bores with a tiny brush and got rid of the vast majority of it, to the point I might actually roll the dice and run it. All the rubber is good and there’s no pitting where the external O rings seal against.
My biggest area of concern however is the internal seal on the valve itself, there’s definitely some pitting in that deep section but I’m not sure how it would effect brake performance, as there seems to be some deliberate controlled flow through there as the rubber seal has grooves(like a tire tread) to let high pressure brake fluid pass to begin with. In fact it’s the only possible way for pressure to go to the rear brakes; the master circuits enter from the top, there’s unrestricted flow to the front calipers from the sides and the rears on the bottom are physically separated by that treaded seal(controlled leak?) hydraulics aren’t my strongsuit so I’m probably huffing copioum somewhat but the only thing that acts on that spring is the rear brake circuit so… We’ll see. Right now I kind of trust what I have despite its wounds over another used one after tonight’s dissection.
Oh on the full topic of the thread at hand I also gutted the last remaining ABS wiring to the rear sensors! That’s actually a shitload of wire! I know it’s not going to be impressive in the grand scheme but I from the start intend to weigh the FULL wire + HCU + sensors of the ABS system to see what they add to this platform down to the ounce… minus the dashboard harness, since that’s a pain in the ass, marginal and ALL MN12 dash harnesses are prewired for the couple of ABS circuits within. I for one am curious enough to see the tally that it’s motivated this pointless project of mine![]()
The white crystals are a glycol hydrate; you might get the white crap out by baking it in the oven. It should decompose back into water and glycol, and evaporate, 250-275 should work. Those al pieces are anodized, and brass rust is green. Tin rust,lead rust and al rust are white. copper,brass and bronze are green. (bronze and brass are mostly copper.)
A few drops of battery acid in water would eat the corrosion, and brighten the brass.
GO COUGAR!I always thought of this is a radical mod when I had it and went back to stock for keeping it original sake, but recently decided what the hell and threw it on. How noticeable is it?
Hey Kenz, take 20 min and some steel wool and polish up those pipes!Drained the oil while it's in the air waiting for fuel pump parts, going to put in a new FL820s. I bought a box of 12 fl820s in 2019, they were $4.19 each back then. Guess that was a good purchase since they are about 8$ each now.
Here is a picture of my fancy exhaust setup... It's a Dynomax mid pipe, and muffler delete. IDK why these cars came with a mushed mid pipe from the factory?
Was going to change the exhaust setup, but decided to just get some new tips to replace the rusted ones. Maybe ill even be cheap and get the steel wool out and see if they clean up
Today (actually yesterday) I ran codes on the car. I noticed that the idle was low after finishing the exhaust and it seems to be missing every once in a while at idle. the codes came back that the idle was correct (and has not been an issue after running the tester) and that I still have 137/173 codes and I bet its the injectors are just crap and dumping fuel into into the intake, or at least one or two are crap.
I had read in an article while researching mis-firing, the issue could be the coil, wires or plugs. I got to thinking that I was messing around the plug wires disconnecting and reconnecting my O2's so I went around and pushed all my plug wires in. I ran the car again and the mis-firing went away, but I do have a hesitation, slight, but if you listen, you can hear it. The idle is staying at 750 and the car does act up sometimes, but I blame age more than anything.Today (actually yesterday) I ran codes on the car. I noticed that the idle was low after finishing the exhaust and it seems to be missing every once in a while at idle. the codes came back that the idle was correct (and has not been an issue after running the tester) and that I still have 137/173 codes and I bet its the injectors are just crap and dumping fuel into into the intake, or at least one or two are crap.
By the time you get home tomorrow that will no longer be fresh steel.
This is the first time I've ever heard of half a brake job being finished months later.
sometimes things go that way..Apparently the Focus wanted to join in on the fun of brake projects. Did only the left side in the summer and put off the right because it seemed… okey… and well I was lazy. Well it went bad bad this morning! Real bad!
Drove it home for 5 miles using the handbrake, when I was using the pedal it smelled like car fire
All fixed though. Gotta love the sight of fresh steel on a salty car
No comment, I'm just a mechanic...This is why you should never consider “mechanic owned” in used car ads as a selling point![]()
Try resetting the eec, and let it relearn with all cylinders working.I had read in an article while researching mis-firing, the issue could be the coil, wires or plugs. I got to thinking that I was messing around the plug wires disconnecting and reconnecting my O2's so I went around and pushed all my plug wires in. I ran the car again and the mis-firing went away, but I do have a hesitation, slight, but if you listen, you can hear it. The idle is staying at 750 and the car does act up sometimes, but I blame age more than anything.
