I bought more E85 for it … put in gas cans not the car.
Yes. I run E85.Is your car modified to run on E85? If so, what does that entail, and what are the benefits?
Oil changes... meh. Over and done with within about 15-20 minutes. The thing I hate the most about other people doing oil changes... they always overtighten the drain plug and filter! When I can do the oil change for $30-$35 using full synthetic in under 20 minutes, and with the cheapest service shops wanting 2-3x that... I'm a miser, to be sure.![]()
That was the best mod Ford did after the 1990 models.There's a pour lip on the crossmember.
It sucks on the 5.0, too. We did my oil change once when I first got the car, and Dad said "pay someone to do that shit next time"I thought the 4.6 was the only one with the sway bar in the way.
That unlocked some memories right there of my Dad and I having some of our biggest arguments under a car.It sucks on the 5.0, too. We did my oil change once when I first got the car, and Dad said "pay someone to do that shit next time"
Mine just drains onto the power steering hose tucked in the crossmember, gets caught on that and drips from there basically right under where the filter attaches to the block. It never makes it to that little lip in the crossmember. I keep promising myself I'll eventually replace the engine mounts and it will get better, but we all know that won't happen.There's a pour lip on the crossmember. I loosen the filter a couple of turns, and let it drain into a pan,
How is E85 on the seals and gaskets? I recall that the corn oil crap they put in regular gas can effect gaskets, but I don't recall how far back the age of the car before it can cause issues.Yes. I run E85.
Ape arms and oil filter wrenches. They don't know that you only use the wrench to REMOVE the filter.... I truly have no clue how people overtighten filters that bad.
Beautiful ride, ugh, I wish it was getting to the right season. -22°f here today, car is under 2 feet of snow, im jealous of being able to work on a car in February. Maybe one day ill live somewhere warmFilled up with 93. It was about on fumes since I just changing the fuel pump. Put in a can of 134a, aired up the tires and gave it a wash! Pretty much spring here now so it's ready for summer
I was getting sick of the drone with no mufflers, so put on a pair of glass packs. I'm undecided on the look but I like that the exhaust exits straight out the back now. Sound is much more mellow but still aggressive, it's way quieter on the highway. Going to try some chrome tips on it
These are what I used and with the angles in and out they actually fit perfectly in place of the factory mufflers - https://www.summitracing.com/parts/APH-351822S
Not unless you flip it over (strap type of course).Ape arms and oil filter wrenches. They don't know that you only use the wrench to REMOVE the filter.![]()
That's a given. I have used a filter wrench to screw in some filters because my hands were too big to fit in the are to tighten it. But of course, turn till it stops with little to no pressure, tighten 3/4 of a turn. AND LABEL THE DATE AND MILEAGE!!!Not unless you flip it over (strap type of course).
I think you mean LABEL.AND LABLE THE DATE AND MILEAGE!!!![]()
