Ericv8thunderbird
Love the red!View attachment 6803
Started putting the interior back together on the TC.
Automatic Transmission Cooler Line Kit -6AN Push Lock Hose Kit 4R70W 4R100 E40D | eBay
4R70W 4R100 E40D. Automatic Transmission Cooler Line Kit. -6 AN Black PUSH LOC Hose with Fittings For. 15' FOOT OF PREMIUM -6 PUSH LOC HOSE.www.ebay.com
What do you guys think of this kit? Pretty cheap, it does use cheapy oil lines but it should be good enough.
Overall well. There was some tweaking and minor clearancing to make things fit well. It isn’t a 2 hour swap, and it doesn’t have the same level of precision as a factory original piece, but I am happy I got it. The simplicity and accessibility it gives under the car is pretty great.How'd everything fit?
Yea this kit is all rubber hose front to back, why is only rubber a bad idea?? I currently have a Hayden cooler also fitted to cut metal trans lines. It does work fine but just wanted, was thinking of upgrading to the trucool 40k cooler .Define cheap? My Hayden cooler cost half that and that was all I ever spent on a trans cooler. The lines were from the parts store and probably cost under $10, spliced into the stock hardlines. What you do not want are rubber lines all the way from the transmission to the cooler and back, which it seems like that kit does.
Awesome!View attachment 6803
Is this for a tranny cooler?![]()
I hate to say this, but shop around some more. I am not at my PC, so I can't share my pics of when I did mine, but I know I did not pay that much for my kit. That is hoses, etc. I did have to buy separate brass fittings for the engine rad, the kit fittings where not the same thread. I think I did a write up too.Define cheap? My Hayden cooler cost half that and that was all I ever spent on a trans cooler. The lines were from the parts store and probably cost under $10, spliced into the stock hardlines. What you do not want are rubber lines all the way from the transmission to the cooler and back, which it seems like that kit does.
I thought I was looking a sink drain at first.
That’s a problem that I have, I have no idea what threads or size fittings it would need so a kit like that makes it easier for dummies like me.The big problem with all metal lines, is coming out of the side of the trans. To come out with a 3/8" line, it won't bend that far without kinking. The threads in the side of the trans are BPST(British pipe straight threads) I bought an adapter, bpst to npt, screwed a full flow 90 on that,and screwed my NPT lines into the 90. The hole in the trans is smaller than 1/4"npt, imho.
I am at the stage of Plumber's nightmare routing the IC tubes around the AC lines.
I have seen those nightmares in my bill.That's my bread and butter. I could re-route those AC lines and air charge tubes like a pipe wizard.
You don't want to know what our nightmares consist of.
Yes, and why I learned plumbing. I was lucky though and had a plumber that used to teach me everything he knew. I am also lucky because i have a crawl space to access the pipes. Everyone else in the neighborhood has floors of concrete and have to jackhammer it up to replace the pipes.View attachment 6955
Something like this ?? From my shops T&M tag ..
Minimum is 2 hours just to show up; 4 if I pick up a tool.![]()
Dang, you are on the other coast!That's my bread and butter. I could re-route those AC lines and air charge tubes like a pipe wizard.
