- Sep 21, 2023
- NJ
- 1996 Tbird LX, SVO blown 4.6 // 1990 Tbird SC Drift missile, OHV 5.0
Now would be the opportunity to do an easyrod conversion![]()
The trunk/wing was twisted so it didn't make sense to use it, and the wing was made from cheap home Depot supplies so it didn't make sense to spend the time to save it.Why lose the wing? It didnt look bad,imho.
I'm still going back and forth. If I run out of time for the season, I'll rattle can the mismatched panels red. But if I have time, I want to go with a livery that would suit a drift car.Wile, I don't know if you had already said, but are you going to keep it the same color or go for a different color?
Triming down the stock stuff. Saves money.Are you doing a standalone ecu or just trimming down the stock harness?
Ill try to get them for you.I would actually be more helpful to see the wire colors than connector styles. A lot of that is way different on early MN12s than later MN12s I’m far more familiar with but the first pic is definitely the secondary junction block(basically a fuse block without fuses) the second pic looks like the blower motor plug, but the third and fourth I’m not truly sure.
DriftyRod! Would start a new era...I’m fearing I may be right lol
Would this also apply to a 93 sc?Here is a link to the complete 1990 large-format wiring diagram set in the highest resolution I could get it. I also included the standard circuit chart (by number and color) from the front of the book. I figured this would be the most valuable to you for nit-picking the whole car. If you can't see anything clearly, or if you need anything from any of the other manuals just hit me up.
1990 MN12 Large-Format Wiring Diagrams (Hi-Res)
So I should probably invest in a manual for my year? Need to delete lots of stuff from the harness when I get to that point in the build. Any recommendations for a manual?Some basic stuff would be applicable but there was a lot of wiring changes that took place by 93(like colors for circuits or the Teves IV ABS layout), so depending on what you’re working on you’d actually possibly have an easier time using diagrams for a 94-95 to reference for your application.
View attachment 10435View attachment 10436
Is it garbage? Yes.
Is it permanent? Not right now, but it might be if the resin finds a way through.
Gonna do the other side tomorrow, then it's gelcoat and fiberglass time.
Thank you sirYes. Nothing will top one of these, and like this one they can still be had ridiculously cheap.
The factory service manuals are good to pick up as well but it’s less year specific and there are arguably better procedures for diagnosis and repair gathered here on the forums than they have. The EVTMs however are basically essential when it comes to digging into wiring for a specific year.
It won't be an easy rod, but idk if you guys will like what I'm actually doing any better lolThe skirted fenders are not easing my easy rod suspicions![]()
