Starting with this, this was supposed to be a simple 2min job. Easy, spin off the old bib spin on a new bib. Why? It was leaking. I replaced the gasket about a month ago, and all it did was make the leak worse. Easily a gallon of water every 15min.
So, I go spin it off and all what happens is it breaks the solder joint and now it's leaking from the "T". Off to Home Depot I go! I get new hardware solder my joints and go to remove the old stuff. The old shit DIDN'T WANT TO COME OFF!!!
I legit spent at least an hour trying to pull the old copper pipe out from the 90* nub. Eventually, I did get it out. I sanded everything down, and installed all the new "T" stuffs. It fights me a little bit, but I eventually get it all on, turn on the water, and it's leaking still
!! Albeit, the leak is now at the disconnect above the water pressure regulator. The leak is also more of a slow drip than a persistent trickle like it was before at the bib.
Basically, I need to revisit this and get it fixed right. Probably next weekend. I had more stuff to do. I'm thinking maybe it needs a new regulator anyway. It's already 10-ish years old.
