CDsDontBurn
I still have a couple leads on printers here in SoCal, so that's two of us to supply us MN12 enthusiasts with bezels
Already is. I bought a Crealty 3 Pro for $350 in 2019. The updated and improved 2024 version of it – the V2 Neo – is going for $199 today.Printing should get cheaper over time.
Now we just need reliable printers for hobbyists that have beds bigger than 125mm x 125mm.
A really cool variable on the whole thing would be merging the cluster and radio bezel into one piece. But that’s coming from a hoarder with nice oem pieces![]()
Matt, youre the craftsman; how would you feel about building a large format 3d printer? I'd be happy to kick in, and there's a market for parts. I just can't physically build it.
You could physically make a larger 3D printer. It's just a print head with servos to control position in the X, Y and Z axes. A larger plate with longer arms and belts with the appropriate framework to suspend said arms/belts (and servos) is all you really need. You could build it out of lumber if you want.
Now, modifying or writing the software that controls the printer, that's the tricky part. Certain machines might have programming more customizable/accessible than others. Come to think of it, I honestly wouldn't be surprised if there are companies out there that sell "kits" with a print head and modular support/control mechanisms with customizable code for this purpose.
Same goes for skydiving.As the saying goes "Any landing you can walk away from is a good one "![]()
That was the airport I was planning to fly into when we went to Chicago last spring. I had made arrangements with Revv for them to have a car for us.
Small world.
Small project, did I mention I bought and pseudo restored a motorcycle?Well I fixed/modded something that’s been driving me nuts. The stock rear turn signals with their long rubber stalks after 20 years have warped and sit crooked and no amount of washer stacking and bending of the brackets I tried helped, so I fixed it. I used only my hacksaw( I’m a very good hack!), a set of lamp nipples
from the hardware store and a little more bending of the brackets to get the mounting up to snuff. Saves me a few bucks on aftermarket pieces that by most accounts isn’t even that bright.
Also painted the lenses red and changed the bulbs from 1156s to 1157s to make it more overall visible. Really important since I’ve ridden the this death trap all of 10 miles all summer![]()
I think I bought new ones from dennis kirk, a few years ago. It's a pain, but I'm going to lube all the cables as soon as I finish the carbs. My manual dexterity sux, lol. Carbs also suck, have I mentioned it?I'm trying to find another set of inlet tubes, between the airbox and head, I'll put a set of injectors in, and use my spare eec to run it. It's an inline 4; I'm sure I can write a tune for it.
All electric cars won't start without voltage... (sorry grog, had to throw that in)Some vehicles wont push start, without voltage. I had a subaru like that.
