Really you just need to take it on a part by part basis. I still roll the dice with used given the opportunity since I’m a cheapskate, but a whole assembled shortblock has a lot to hide until you take it apart where a set of pistons by themselves, crank etc you can spot or inspect before committing to the buy.
Same goes for buying a modified car ten fold; you’re buying someone else’s problems.
I’m also and avid cheapskate haha from the jump I wanted to take it apart right then and there at the guys house but didn’t have the tools.
The good thing is the crank is in good condition and the H beams look great, I also have the ARP stud kit which is $400 by themselves!! I just posted the block and pistons for $300. Even if I get $200 from this and the $200 from what the guy is gonna refund me I should be $300 into the rods and forged crank. Depending on how the other block is I’m gonna sell this crank also.
at this point I need to get a set of forged pistons. Besides that everything is pretty cheap, bearing, oil pump, gaskets?
question tho, should I have the rotating assembly balanced ?? Some say not necessary, which doesn’t make sense to me. Specially if I’m trying to rev this bitch to 7500!!
