- Oct 2, 2023
- New Mexico
Hi everyone and thank you for this site! Fantastic folks on here.
I have had this issue for some time, well... some 20 years, but it is really bad now, especially with the heat. I turn the key, hear the fuel pump go on, then turn the ignition and click... like the battery is dead. I checked the battery and it has 12 volts (13.98 with engine running), so its not the battery. If I pull the ignition lock out and put it back in, VAROOOM! Starts right up, no hesitation, no signs of a failing battery. As mentioned, this has happened for the longest time, cold, heat whatever, and it happens out of the blue. I even turn the key around and same issue. I can also push real hard on the lock cylinder while turning the key and it will start as well (most of the time).
I believe the car was repo'd before we bought it and if so, the assembly could have been damaged. You might be able to see the inside of the assembly (pic attached) and it does not look right, though I could be wrong.
Any suggestions what I can do? I can't find the assembly replacement anymore and I may have to go to the J yard to get another one. But before I do that, I was wondering if anyone else has run into this and if there is a "stupid fix" (oh geez... that's all I needed to do?).
Thanks!
PS: I am on my 4th cylinder now. So its not the cylinder... or is it? Hmmmm.....
Thanks!
