Post a picture you took today
Dodge can put 2000 horsepower into a plastic Challenger, but this will always be a REAL Demon to me
Coolest looking taillights of the muscle car era IMO it’s weird so many were grandma spec slant 6 powered 😆
I love the 70's Dusters and Darts. Almost bought a '72 Dart Swinger many many years ago. Pea green with a dark green vinyl top. Slant 6 and automatic. Very underrated cars in terms of what you can do to them. Everybody else wants a 'Cuda, Challenger, or Charger. I'll stick with the unwanted models.
I built the wife a pair of pull out shelves for our cabinets today. I just scrap wood I had pulled out of the attic and wood left over from other projects. I got half them sides done in black paint and will probably poly them for preventing scratches and the like.
"why build them when you can just buy them?" My wife said the same thing. two reasons, the price of the crap from China is just ridiculous and the chance to make something with my hands and all the tools I have? Priceless.
Drilled out rear Cobra rotors to fit the MN12 bolt pattern, a 3/4" bit opens them up just enough.
Bought a clearance $14.75 MN12 front hub from RA for test fitting. It has a Koyo bearing and says made in USA on the box. Box looks early 2000's, guess I lucked out and got a deal. I have a good spare now
Temporary storage while I figure out either doing a body swap or fixing it.
Would be interesting to see the inside and underside of the trunk. I assume it all shifted to the driver side causing the wrinkle in the driver's 1/4?
That's fixable with a BFH and some attitude. Lazarus was way more fucked up than that; and I put 400k mi after that.Use a tree and a jack or comealong to get everything back to roughly straight, then pound the body back into shape. HF sells a cheap body hammer kit, eastwood is better.
The entire rear end is shifted over 8 inches and both rails are bent
It tore the mount out of the rear frame on the side that took the hit
Sounds like tube chassis time. You could continue the tubes from the rockers over the wheel wells and to the tail panel. Unfortunately you'll have to cut the entire back "clip" off another car. Likely much smarter to find another car.
One of the other bird drift guys is making carbon panels for these cars. I'm talking to him about getting a set of quarters by the end of the month if I go that route.
That's too bad your car got messed up. Looks like it went out in style! I take it you are all good and no one got hurt?
